Here is an easy modification for your 3.8 ignition -
The DirectHits Ignition replaces your stock plugs and wires with a high-voltage ignition system. The high energy-density spark system produces a flame kernel and flame front that propagates more quickly and completely through the fuel charge. This increases throttle response, acceleration, fuel efficiency and reduces emissions. Long-term benefits include reduced carbon buildup in the combustion chamber and extended service periods. This Electrical Power product improves the transfer efficiency of your ignition system. Its patented technology raises the level of efficiency over 500 times. Upgrade to improve fuel economy and performance and provide cleaner combustion -- all due to increased high current discharge at the instant of ignition.
Each kit includes
DirectHits current peaking capacitors - 1 for each cylinder
High energy 8mm wire set
Premium non-resistor sparkplugs ( Bosch/Accel/NGK depending on the application)
Installation tool (plastic 3/4' 12 point 1/4' drive socket to install the DirectHits properly to 12 inch/lbs of torque)
Dielectric grease for all electrical connections
Installation instructions
We'll be installing this system in our C5 along with a few other vehicles here. I'll post results when I have them.
Tom
Each kit includes
Tom
