Lights dim, RPM's drop - FirebirdV6.com/CamaroV6.com Message Board
  • Lights dim, RPM's drop
    Every time I let off the clutch no matter what gear or what speed, the RPM's drop to about 500 and the lights and all interior lights/radio dims alot. Say if I'm traveling at 70MPH, and I put the clutch in to slow down, the RPM's drop gradually, but when it gets to about above 1000, its drops fast to about 500 and comes back up, and the lights and radio dim when I push the brakes. I installed another idle control valve, MAF and a PCV valve, not for this reason though. Any thoughts? Only thing I can think of is the alternator. Let me know what yall think [img]graemlins/rock.gif[/img]
    \'96 Black Camaro M5<br />17x9.5\" O.Z. Monte Carlos, Eibach sportlines, SLP-CAI, Edelbrock cat-back
    My car does the same thing, its normal.
    If you have your alternator spinning at 2500 RPM, and then slow it down to 700 RPM (where my car idles) its output isn't going to be as high, hence your lights dim. I'm not sure of the exact number, but I'm pretty sure alternators don't put out their full output until near 2000 RPM.
    Your speed has no effect on how fast your alternator is spinning once your clutch is disengaged. At that point there is no connection between your wheels and your engine.
    1997 Cayenne Red Metallic Camaro<br />3.8 V6 M5<br />SLP Cold Air Intake<br />Ceramic Coated Pacesetter Headers <br />Flowmaster American Thunder Catback<br />Full 3.42 & Disc Break Rear End Swap
      True, but I'm wondering if its supposed to drop that fast, I mean sometimes it does it so fast it wants to die out on me, and when they dim I mean they dim bad, its not occasional and its not just a little dim, its like the lights are at half the output they were at first
        its the alt...
        try doing the big 3, camaro alts seem to suck at lower rpms...
        ill be doing the big 3 with 0 gauge wire as soon as it gets a bit warmer...
        White 1998 3.8L Camaro
        Home Ram Air / Free Flow Intake
        Drilled / Slotted Rotors with black painted Calipers
          Yep I get the same thing. Would a stronger alternator stop it?
          Thanks, <br />JAM<p>02 Firebird GT
