POS starter, bad sounds - FirebirdV6.com/CamaroV6.com Message Board
  • #61
    you need that sequence?
    • #62
      Yup, the 41 ft/lbs is the stage torque, then the 90 degrees is the final. I wouldn't eyeball this angle either, I would use an angle gauge for this. I got a cheap Power Fist one from a surplus store here for like $20.00 on sale. It works just fine.
      DZ
      • #63
        First do all the bolts to 20 ft/lbs in the recommended sequence.
        Then do all the bolts to 41 ft/lbs in the recommended sequence.
        Then do all the bolts all the way to the 90 degrees in the recommended sequence.
        DZ
        • #64
          Are MAPs supposed to have water/coolant/oil sludge crap in them??? I think NOT
          Are upper intake manifolds supposed to have water in them?
          Let me get some pictures up, if this camera will work! grrr
          • #65
            MAP is all wet inside
            Intake pic #1
            Intake pic #2
            Upper Intake pic #3
            base of lower intake (the TPS is all crusted/salty looking)
            base of lower intake, the ports are dirty
            rocker arms/valves are really sludged up
            valves covers are all sludged up
            valve covers all sludged up
            [ March 13, 2006, 09:44 PM: Message edited by: slow6 ]
            • #66
              They can have oil and sludge on them, buy should not have water/coolant...youve found your problem...thats where your water is going.
              • #67
                I sure hope so. Gotta finish compression test tomorrow. Clean the valves out(sludge gunk from hell). New upper intake gasket. Should I redo the bottom intake gasket too?
                • #68
                  Me #22lb. Injector
                  How do you disassemble an injector and clean the sonmabit*ch? [img]graemlins/stickpoke.gif[/img] [img]graemlins/slap.gif[/img]
                  • #69
                    If I take the injectors off can I not run a compression test? Would it depressurize?
                    • #70
                      YES, it looks like you have already removed the lower intake, so now you kinda have to.
                      Me #22lb. Injector
                      You injectors look totally diffrent then mine, just clean both ends really well.
                      • #71
                        What year is your car?
                        • #72
                          20002
                          I only think I have the intake plenum (upper) off, but dont quote me on that
                          • #73
                            sorry..lol..i was looking at an upside down pic of the plenum, it looked like the lower intake..lol..sorry. If i was you, you really should go ahead and do the lower one also, now that you have every thing off, it will be super easy. So yes, i highy recommend doing it.
                            • #74
                              why does where the valve cover meets the head, and where the head is, there is soo much carbon build up I guess??
                              • #75
                                There sould be no carbon build up inside the valve covers or around the heads. How ever there will be carbon build up inside the plenum, and intakes, that is thanks to your egr valve.
