Has anyone had trouble with their security light coming on??? Mine comes on sometimes and the car won't even try to start. I have to take the key in and out a few times before it will go off and start again. Does anyone know what could be causing this???
KEY WITH CHIP???
KEY WITH CHIP???
My car looks great and runs good. <br />Please Look at my car, it may be one of a kind!!! Let me know if you like it...<br />Hard to find 1995 Firebird with 3.8<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=429908\" target=\"_blank\">http://www.cardomain.com/member_pages/view_page.pl?page_id=429908</a>Tags: None
<blockquote>quote:</font><hr>Originally posted by Dustin Freels:
Has anyone had trouble with their security light coming on??? Mine comes on sometimes and the car won't even try to start. I have to take the key in and out a few times before it will go off and start again. Does anyone know what could be causing this???<hr></blockquote>
Search...its the resistor in the key....try using an eraser to clean off the resistor contacts...if that doesn't work....you are gonna have to replace the ignition cylinder.<a href=\"http://www.onid.orst.edu/~waltejam/\" target=\"_blank\">98 Bright Red Camaro</a><br />Too many mods to list....check my website
i had the same problem, do u have an aftermarket alarm? either way you can bypass the chip in the key with a resistor.. all you have to do is find the wire cut it, and splice in a resistor with the value close to your keyGreen 97 Camaro RS 30th Ann.<br />3800 II<p><b>MODS</b><br />BORLA rear exhaust section, RKSport Headers, Hi-Flow Catylitic Converter, SLP CAI, Sylvania Silver Star Headlights, Eibach Pro Springs, Bilstein Shocks/Struts, 1LE Front/Rear 32/21mm Sway Bars w/Poly Bushings and Poly endlinks<p>And a bad @SS MTX System
Its a little wire coming out of your lock cylinder that gets pinched whenever you start your car. Over time it starts to pull out (GM ingenuity). Anyways you can do what was said before (disables part of your security system), or change out your lock cylinder and re programs your keys (dealer only).
or you can tear apart your steering column yourself and just fix the broken wire.. (if of course that's the problem)-Brad
2000 V-Star Custom 1100
:rock:
