block check kit - FirebirdV6.com/CamaroV6.com Message Board
block check kit
  • block check kit
    hey all! just bought a sprint palmone treo 600. i'm on it now! killer phone. anyway, ithink I have a bad head gasket. how can I go about verifying this? also what does a block check kit do?
    ~The Guru\'s Guru~<br />1999 Camaro,K&N,!MAF<br />!airsilencer,3.08s,<br />NGK-TR6\'s,Taylor Blue 8mm wires,FRAM,A4,Catco Cat, Magnaflow 3 inch catback,transgo shift kit<br />Waiting: RK sport headers, custom y pipe electric cutout<br /><a href=\"http://www.cardomain.com/id/divinejc\" target=\"_blank\">www.cardomain.com/id/divinejc</a>
    i think you'd be able to pick that up by havinga compression test done [img]smile.gif[/img]
      Check for leaks/Smoke, a compression test SHOULD tell you, but isn't 100%.
      I've got a treo 300 ;)
        I take it that any shop can do a compression test? btw, I have a powertrain warranty so if it is the head gasket, this repair will be for free!! I have not been able to find any leaks except once, under the driver's part of the radiator. so I got the radiator tested and it's fine. but i've seen dripping once below the radiator where the air dam and metal meet. i'm having to add coolant every couple days, would a head gasket leak that fast? nachius, u like the phone? this one is unbelievable!
