Code 0113???? - FirebirdV6.com/CamaroV6.com Message Board
Code 0113????
  • Code 0113????
    i hollowed out my cat and put the powerdyne on the car at pretty much the same time...sometimes when the powerdyne was on it would set a code 0113...just once in a while...i think its "AIT sensor input too high" ...now that the powerdyne is off the car...i still get this code once in a while...can this be from my hollow cat?..did i just fry the AIT sensor?
    AIT = Air Intake Temp
    check your intake air sensor
    www.turbov6camaro.com
    1997 3800 Series II Camaro
      so it doesnt have to do with the cat?...cool...cuz that AIT is like..12 bucks [img]smile.gif[/img]
        not that i know of,
          nice...i'll start with that then..thanks! [img]smile.gif[/img]
            did you ever have the IAT unhooked with the key on?
            1996 Silver camaro Z28. M6,<br />12 bolt, 4.11\'s, posi, Rear cover, Spec stage 2, loudmouth, more <a href=\"http://home.mainstreamtopics.com/?index=3&module=1\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=1</a> &lt;Mods, Pics & more <a href=\"http://home.mainstreamtopics.com/?index=3&module=2\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=2</a> &lt;Fbody Tech Articals
              its possible...but i've cleared the code...can this fry the IAT for good?
                not by unhooking it, your more likely to spike the PCM then anything and that is very rare. Clear the codes and see if it comes back. I doubt it will. If it does we can performace a cuircit test.
