i just bought a body kit and i found that my car is runing a little hot well i found out that my deflector is being covered by the ground effect is there any modifide deflectors out there?
air deflector
air deflector
2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainersTags: None
go to www.wingswest.com they make a lower air deflecter that will go lower then the gfx. thats the way to go1997 Camaro LS1 RS
1994 Camaro - Sold
1999 Trans am Vert - Sold
A Few Mods....
My kit was from Wings West. That bottom air deflector will strike EVERYTHING in the street because it is is so low to the ground! Mine finally broke after about three years of abuse!
If you use a standard air deflector then get a cool fan switch. I went with an adjustable cool
fan switch mod, and I removed the fan connectors
from the factory relay system. Both fans now run at high speed and turn on at 160 degrees. You can get one at your local auto parts store or buy
the aftermarket ones like RKSport and SLP.
mines a xeon kit so ill check out wings west thanks and where can i find the fan connectors from the factory relay system2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainers
get this, its for the vuzage kit http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW*1997 Camaro v6 3.8*<br />President of NorCal Sinister Six
