when i first start up the car anytime of the day..It idles fine but has been fluctuating up and down surging (just alittle) untill i give it some gass and start moving then it stops for the rest of the time.. only at fire does this happen..What could this be? All plugs and wires are brand new and fuel filter...??
Idle at start...
if you havn't touch you fule filter i would start there, it only about 11bucks and easy to dowww.turbov6camaro.com
1997 3800 Series II Camaro
could some one post directions, (pref with pics of location of components) or a link with the intructions plz. thanx.Ummad!<br />2k pewter maro M5. 160 thermo, WhisperLid w/K&N Filter, Jet PCM Stage 2, Free Ram Air, Air Silencer Delete (purchased already and) waiting to install manual fan switch, air/fuel ratio guage.
Try your IAC. it's on the throttle body. Black and kinda round, held on by 2 T20 torx screws and has a 4 wire connector. pull it out and get a new one and clean the passageway with car cleaner.1996 Silver camaro Z28. M6,<br />12 bolt, 4.11\'s, posi, Rear cover, Spec stage 2, loudmouth, more <a href=\"http://home.mainstreamtopics.com/?index=3&module=1\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=1</a> <Mods, Pics & more <a href=\"http://home.mainstreamtopics.com/?index=3&module=2\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=2</a> <Fbody Tech Articals
Originally posted by HBHRacing:
Try your IAC. it's on the throttle body. Black and kinda round, held on by 2 T20 torx screws and has a 4 wire connector. pull it out and get a new one and clean the passageway with car cleaner.www.turbov6camaro.com
Nope.1996 Silver camaro Z28. M6,<br />12 bolt, 4.11\'s, posi, Rear cover, Spec stage 2, loudmouth, more <a href=\"http://home.mainstreamtopics.com/?index=3&module=1\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=1</a> <Mods, Pics & more <a href=\"http://home.mainstreamtopics.com/?index=3&module=2\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=2</a> <Fbody Tech Articals
Nope.www.turbov6camaro.com
umm.. not your IAT.. your IAC..1996 Silver camaro Z28. M6,<br />12 bolt, 4.11\'s, posi, Rear cover, Spec stage 2, loudmouth, more <a href=\"http://home.mainstreamtopics.com/?index=3&module=1\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=1</a> <Mods, Pics & more <a href=\"http://home.mainstreamtopics.com/?index=3&module=2\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=2</a> <Fbody Tech Articals
i don't think my 1997 has one, it was just hole that goes past the TB plate and in to the upper intake......
any only thing on the TB is the TPS that i could find and the MAFwww.turbov6camaro.com
