HELP!!! - FirebirdV6.com/CamaroV6.com Message Board
HELP!!!
  • HELP!!!
    my car is still F***ed up!
    i thought i had touched the MAF so i replaced it, and it did no good whatsoever.
    there was lots of water in the exhaust when it ran, and a little bit of maybe oil maybe fuel in the intake when i looked...
    i seafoamed on monday, put the remaining 1/2 can in the oil on tuesday because i'm fixing to get it changed, took off my whisper lid to check for pinholes, saw a bit of grass on what i then presumed to be the MAF sensor, so i removed it and about 3-4 hours later i started my car up and it has run like **** ever since! :(
    hmm.. sounds like you shuld have left the grass alone..
    What else do you think the problem may be?
      i dunno why, but just out of curiosity i went out and started her up... purrrr... took her around the block, perfect! replaced old maf sensor in it, still great! so thx but i guess if it doesn't work, mess with it, you never know when it will. i haven't got the slightest clue why it suddenly started running great, but i am glad it did [img]smile.gif[/img]
      [ October 08, 2003: Message edited by: 98v6 ]</p>
        Couple rules for advanced tech is you need to make your post titles descriptive. HELP is very vauge.
        Also, the place for problem diagnosis and such is general help so I'm going to move this there.
        Also, your description of your problem is very vauge. Describe how the car starts and drives. Give DETAILS.
        Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
