IAT Resistors any info? - FirebirdV6.com/CamaroV6.com Message Board
  • IAT Resistors any info?
    Okay we all know about the resistor tricks for our IAT sensors. My IAT sensor is shot and I have to wait a week for it to come in, and I am having horrible gas millage right now somewhere around 18mpg on 70mph freeways! This is pretty bad considering... So I have been highly considering picking up a resistor from raidoshack or something to just plug it for now maybe balance it back out a bit, considering my engine is DIEING when its colder than about 20degrees, until its warm.
    I also know that alot of people are interested in doing this very controversial modification. Basically for daily driven street vehicles, its stupid! The power gain is not worth it, and the variance day to day is too much to really be worth anything.
    Now if you drag race on days that it averages 80degrees outside, now that would make it worth it for that DAY! A little timing advance and a little rich running wont hurt, but there are extremes. People say a colder running engine gives better performance, so why don't we keep them at 100 degrees flat? Exactly.
    Well basically I was wondering if anyone knows anything about the different resistor ratings and the approximate air temp sends.
    As in- 10k ohm = 50 degrees?
    15k ohm = 40 degrees?
    Thanks for any help in this topic!
    1995 Camaro 3.4 A4<br /><br />CAI,IAT Relocate
    4.7K ohms would make it think its 57*.
    Black \'94 Trans Am A4- SLP CAI & Loudmouth<br />Red \'93 Firebird A4- Ram Air under the WS6 hood, !cat, exhaust.
      I just picked up a pack of 10k resistors and plugged one in, its about 30-35 degrees outside or so, and my car runs fairly smooth, and starts nicely. I'm not sure what temperature that resister associates with but. I can feel more low end power, and I just doubled my gas millage! lol, goes to show what an out IAT sensor can do to your performance.... :-/
        Note than any IAT below 104° will result in absolutely no change in spark advance. Only when it reaches 104° and up will it begin to pull some timing. Even then it's no more than 3°. The sensor here should not effect highway mileage while the engine is warm.
        </font><blockquote>code:</font><hr /><pre style="font-size:x-small; font-family: monospace;">°C °F OHMS
        100 212 177
        90 194 241
        80 176 332
        70 158 467
        60 140 667
        50 122 973
        45 113 1188
        40 104 1459
        35 95 1802
        30 86 2238
        25 77 2796
        20 68 3520
        15 59 4450
        10 50 5670
        5 41 7280
        0 32 9420
        -5 23 12300
        -10 14 16180
        -15 5 21450
        -20 -4 28680
        -30 -22 52700
        -40 -40 100700</pre>[/QUOTE]Moving to Gen Tech.
        [ March 01, 2006, 01:17 AM: Message edited by: 98Camaro3.8 ]
        Matt
        1998 Mystic Teal Camaro M5
          What kind of gas milage are you getting now? did it really dubble it. I might have to try something like that. My iat is always about 8 degress higher then the actual out door timp, i know this because i have read it with my scanner while driving.
            Well it seemed that way for a little bit, actually I went from around 17-18 to around 24-25ish... Still not quiet there... But we will find out what happens now that he was so kind to add the list of numbers for us.
