Headlight Problem - FirebirdV6.com/CamaroV6.com Message Board
Headlight Problem
  • Headlight Problem
    Maybe I put it on the wrong forum....
    As most of us know, the headlights on the Firebirds have never been perfect. As is the case with my third 1998 Firebird. The drivers side motor keeps spinning and grinding every time the headlight closes. This occurs for about 6 seconds, and then stops. Someone suggested it was a relay problem that doesn't tell the motor when to stop. Is there anything I can do about this or do i have to take it to the Stealership to get it fixed? Any help is greatly appreciated!!
    Search for it....there is a ton of people who have had the same thing.
      I had the same problem and it is a very easy fix. Like speedy said, do a search.
      New Toy Red 94 Formula LT1
      RT: .0006 60': 1.894 1/8 mile: 8.351 @ 84.89 1/4 mile: 12.974 @ 107.81
      crashed Red 96 Camaro 3.8l: 14.91 @ 92.38
      The ex wife's Black 98 Firebird 3.8l: 15.23 @ 88.12
        Thanx for the posts guys, but after searching, this is the only thing i came up with
        http://www.bfranker.badz28.com/headlightfix/#FreeGuide
        Does his "free fix" sound right? and has anyone had any reocurring problems?
          That is it!!!
            Yep, the nylon gear gets worn down. The motor doesn't have a spot that it turn off, the circuit just cuts power when it senses an increase in load. All you have to do is flip the gear around. I also once saw someone who made brass gears for it, but don't know where (or who) sells them.
            2000 silver A4 Camaro<br />Whisper lid; Free Ram Air; BMR stb; MSD super conductor wires; Gatorback belt?<br />1986 RX-7 (daily driver)
              Scroll up on that page... :D
                What happens if you don't get that problem fixed?
