Antifreeze smell - FirebirdV6.com/CamaroV6.com Message Board
Antifreeze smell
  • Antifreeze smell
    Sometime after I drive I can smell Antifreeze, I have looked all under the hood and can't find no leak, and level of the coolent seems good. I am just wondering if maybe I am missing a leak or if I smell it sometimes that is nomal.
    Thanks
    1994 <br />3.4 V6<br />black firebird
    Heater core?
    \"If I have seen further, it is by standing upon the <br />shoulders of giants.\" (Isaac Newton)
      I had a leak that I could only smell intermittently and couldn't find the leak. Well I finally figured out it was the water pump seeping and since it was dripping near the serpentine belt it was not puddling anywhere except a little between the harmonic balancer and the block.
      1997 Camaro 3800 5-speed<br />Flowmaster 80 series catback dual exhaust w/ chrome tips and !cat mod<br />K&N Drop In w/ Removed silencer<br />Freedom Designs STB<br />Motorola Hands Free Kit<br />Code Alarm Security System<br />Eclipse 5441i and PPI Amplifier<br />Q-logic dual enclosure w/ Polk 12\" subs<br />Reflective Concepts rear fill<br />Rear Front and Fog black outs<br />20% side tint 5% rear tint
        it is your water pump, you wont see a leak but take it to have it checked. Water pumps always go out for some reason.
          sounds like you have that,"not so fresh feeling". it happens, usually when it warms up, like in the Summers Eve. you must doushomething about it, immediately!.........j/k
          96 wht. firebird 5sd. rk sport headers,3in.catco, spintech catback,CAI,FRA,3.42/lsd 180*t-stat, centerforce dual friction clutch, ls1 driveshaft, polyurethane trans. mount.<br />01 blk. z28 m6, borla exht, lid, k<br />+n, sfc., chrome 18in. y2k c5 wheels.
          • Andy H
            Transmission removal help!!
            by Andy H
          • 2.8 Bird
            Abs inop
            by 2.8 Bird
          • fishin
            by fishin
