i dont think its overheating buuutttt. - FirebirdV6.com/CamaroV6.com Message Board
  • i dont think its overheating buuutttt.
    I get on the freeway and goo less than a mile and the car says check guages, it in the red soo im nervous. i pull off the freeway and the car is running normal and i pop the hood in the gas station and put my hand on the manifold and its cold to the touch, mind you its like 40 degrees outside. the temp goes down really fast as soon as i stop. once i pull of again it shoots up and withn 3 secs its back buried past the red again, at the light within 3 secs it back at the middle wtf. everylight it eventually goes almost to the red and then as i pull off it drops wayyyy down then creeps back up to the red???? wassup :(
    \"Ride this MF till the wheels fall off, live yo life\"<br />Martin Lawrence
    umm thats wierd
    its not your fans.....
    could be water pump
    thermo sticking....
    i don't know
    www.turbov6camaro.com
    1997 3800 Series II Camaro
      thermo sticking... not sure i understand, does that mean thermostat is broken? thats what i figured it was too
        yeha some times they get stuck closed, but if that was the case you would overheat if you was moving or sitting still.
        how many miles on the car?
          Mine does the same exact thing your going along then bam check gauges comes on and its in the red...I just pull over fill up the radiator to the very top and it stops. I just changed my thermo and it still does it so I dont know, it might not be the thermo
          I would like to know too...
          <b><a href=\"http://www.cardomain.com/id/onebad9d5\" target=\"_blank\">1995 Red 3.4L Camaro</a><br /></b><br />Dont laugh if you see me pushing, no reverse, tranny needs rebuild.
            UMM YOU COULD HAVE AIR IN THE SYSTEM. TRY BEELDING IT
            ALSO YOU YOU HAVE TO FILL IT YOUR LOSEING FLUID SOMEWERE
              Make sure you still have that black plastic airdam underneath the nose of your car. It directs airflow up in front of your radiator. You will overheat without it. My dad has warned me about parking because of this very reason, as soon as you get onto the freeway there is not enough air to cool off the radiator. Otherwise check the thermo and replace your coolant, 30$ well spent for those, extra insurance for the price.
              255/50R16 Tires, Pioneer Deck, Pioneer 4 Way speakers, PPI Amps, JL subs, Spec Stage 3 Clutch, Optima Yellow Top
                oh yeah for got about that thing lol
                  ok soo im on my way home and poof bellows of white smoke and the sweet smell of antifreeze. dern shame gasket or cracked block or somethin.
