Fuel Filter - FirebirdV6.com/CamaroV6.com Message Board
Fuel Filter
  • Fuel Filter
    where is it located?
    for a 3.4 camaro
    UNDER VEHICLE, DRIVER SIDE, BELOW SEATING AREA, FRONT OF REAR WHEELWELL, MOUNTED ON CHASSIS IN FUEL LINE.
    Not shouting, this was copied from a file.
      well today I went to change it but the damn bolt is so rusty I could not get it off :mad: can someone tell me which way does the bolt come off?toward the passenger side?
        lefty loosey ..righty tighty!!! Also look into some good lubricant with anti rust properties and put some on the bolt..then try.
          If that doesn't work, use vice grips and don't screw up the thing too bad.
            before you screw up the lines go and pick up a set of line wrenches...
            1996 Silver camaro Z28. M6,<br />12 bolt, 4.11\'s, posi, Rear cover, Spec stage 2, loudmouth, more <a href=\"http://home.mainstreamtopics.com/?index=3&module=1\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=1</a> &lt;Mods, Pics & more <a href=\"http://home.mainstreamtopics.com/?index=3&module=2\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=2</a> &lt;Fbody Tech Articals
              had to remove the fuel line and then take the filter off.well I got it off
                did you cut the lines? I'm confused
                  And dont forget to relive your fuel pressure before you get started , you dont need to be breathing in all that gas while its pouring out of the line . [img]smile.gif[/img]
                  98 silver camaro t-tops , loaded<br />NGK plugs , Taylor 8mm wires , Optima Red Top .
                    where would the filter be located on a 3.8? And how do you relieve the fuel pressure in the lines?
                    1996 Pontiac Firebird<br />Flowmaster Exhaust, Custom Cold Air Intake, 3.42 gears with LSD
                      Same place. All you have to do is take your gas cap off and the pressure is released. Don't think for a second that you won't still leak gas though (it's a slow drip).
