I like quakerstare 5w30 full synthetic, Mobil 1 is probly better but its alot more expensive. I would definatly suggest going with a full synthetic oil. And a BOSCH oil filter, there my favorite.
I personally have found the Mobil1 and Valvoline Full Synthetic oils to be the best oil brands under $5/qt, and I run Mobil 1.
There are 2 filters for the 3.8, the AC Delco PF47 and PF52. The PF52 is a longer filter with more flow capacity and a longer life. It costs no more than the PF47 and is a much better filter. Cross reference the Delco PF52 to the brand filter you like - you'll find the longer filter in that brand no problem [img]smile.gif[/img] . Heck, the Walmart SuperTech Synthetic filters are really good, and theyre only $2 (made by champion).
Oil types such as 5w-30 and 10-30 are based on viscosity at a given temp. Each grade of oil has a range through which the oil works well at. Do a search on the web or get a book and it will tell you the temperature range and all the differences between the different types/grades of oil. 5w-30 has a wider range of acceptable temperatures to which it is suitable for. If you need more info then ask. I'll scan a page out of a book at oil types/grades and post it for you and anybody else that wants it. Maybe it should be placed in the tech database for reference.
P.S. I personally use only 5w-30 Mobile 1 either the drive clean formula or the regular full synthetic.
[ June 18, 2002: Message edited by: Skullcamaro ]</p>
1994 Camaro<br />3.4L V6 Automatic<br />K&N FIPK&Gold Oil Filter,Ravin Performance Exhaustw/Dynomax MandrelBent3\"I-Pipe&S Pipe&Catco 3\" HiFlow Cat.,ASP Crank and High AMP Alternator,U.D. Pulley Set, Bosch Spark Plugs and Oxygen Sensors, Taylor Wires, B&M E.ShiftPlus, 160 thermostat,Zexel Torsen L.S.D., CSI Remote Mount Electric Water Pump & Temp. Controller & Flex Hoses, ALM. Drivshaft, Diamond SubFram Conn.<br />COMING SOON: 350 or 502 RAMJET ENGINE & Big Block Hood<br />NJ V6 F-Body Club<br /><a href=\"http://tristategm.com/NJFbV6/\" target=\"_blank\">http://tristategm.com/NJFbV6/</a><br />Street Lethal F-Body Association <br /><a href=\"http://www.slfba.com./index.html\" target=\"_blank\">http://www.slfba.com./index.html</a>
I thought that our cars recomend 10w-30 for normal
warm weather and 5w-30 for colder weather.As of filters i prefer FRAM, they are really good in my opinion.I got the oversized filter wich is the 3980 just in case someone wants it. [img]smile.gif[/img]
Up for sale is my 2001 Chevrolet Camaro 3.8 in need of some TLC and help. I’ve owned this vehicle the past 18 years (since 2006) and it’s been very...
