My turn signals no longer work, although the flashers still work. Everything else checks out (bulbs, etc.) so I am going to assume it is the signal stalk (and inside switch) that has failed. Has anyone replaced this? Do I need to remove the steering wheel to access it? Thanks for any help.
Turn signal switch question...
what is the indicator doing? staying solid and not flashing? generaly a switch failure will result in no bulb activity on one side or the other. a bad flasher will result in the bulb lighting up but not blinking. Turn signal faults are rare.1996 Silver camaro Z28. M6,<br />12 bolt, 4.11\'s, posi, Rear cover, Spec stage 2, loudmouth, more <a href=\"http://home.mainstreamtopics.com/?index=3&module=1\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=1</a> <Mods, Pics & more <a href=\"http://home.mainstreamtopics.com/?index=3&module=2\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=2</a> <Fbody Tech Articals
the hazerds are on a seperate circut. Check the Turn/Back up fuse..1996 Silver camaro Z28. M6,<br />12 bolt, 4.11\'s, posi, Rear cover, Spec stage 2, loudmouth, more <a href=\"http://home.mainstreamtopics.com/?index=3&module=1\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=1</a> <Mods, Pics & more <a href=\"http://home.mainstreamtopics.com/?index=3&module=2\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=2</a> <Fbody Tech Articals
