Has anyone here have replaced a water pump from a bonnie? I'm stumped on these two last bolts that is sitting infront of the motor mount 1 inch away from the engine. My socket wrench can't get into the bolt so I can unscrew it. The pivot adapter can't fit between it either...HELP!
Bonneville question...
You have to remove the engine mount from both the engine and frame. Support your engine with something (a jack with a board on top of it), and then I think there are 4 bolts holding the bracket onto the frame there (2 on top, 2 on the side). I think there where 2 bolts holding it onto the engine. Once thoes are out you have to work it a bit to pull the mount out. Then you can get at thoes two bolts on the water pump.
It's a pain, so much easier on the f-body 3.8.<a href=\"http://www.fatninjas.com/camaro\" target=\"_blank\">\'96 Camaro Convertible</a>
I can see this isn't a mechanic friendly. Da*n, this sucks! This is going to take all day to take that pump out. [img]graemlins/crybaby.gif[/img] :mad:<i>00\' NBM Firebird~T-5<br />60\': <b>2.29 sec.</b><br />1/4: <b>14.7 @ 95.5 MPH<br />Ask not what your country can do for you, ask what you can do for me.</b></i>
water pump = PITA on a bonne.
I had a 92 SSE before my WS6.
I almost had to to a water pump, but it turned out to be a hose connector busted above the pump, and had coolant leaking down the pump.
I traded it in shortly there after.
Ryan.1998 Ws6 Ta M6 #370 Bright Red<br />Custom \"NX\" style switch panels $35<br />Plug in fan switches $50 <br />SLP lid, Pro 5.0, Corsa, Custom Fan switch<br />....vortech waiting to be installed.
<blockquote>quote:</font><hr>Originally posted by navyblue2000:
bene, your sig bothers me every time i see it.
your 60' should be 2.29 sec, not 2.29 ft.
;) <hr></blockquote>
Hey! Thanks for looking out! EDIT sig initiated. ;)<i>00\' NBM Firebird~T-5<br />60\': <b>2.29 sec.</b><br />1/4: <b>14.7 @ 95.5 MPH<br />Ask not what your country can do for you, ask what you can do for me.</b></i>
by DongrossmdI’m new. I actually don’t own a Camaro or firebird. I do have a 2000 Camaro 3.8 fly by throttle and 4l60e. This is installed in a 1980 Triumph TR7...21 hours ago
