SES light - FirebirdV6.com/CamaroV6.com Message Board
SES light
  • SES light
    I did a search and read up on all the good info. Just want to make sure there is nothing that "I" can do. Driving today and all the suddent he SES light turned on, can't tell a difference with the car, the perfomance and stuff is fine. Checked all the stuff like gas cap and IAT and what not and everything seems to be working, is there anything else that i can do before taking it to a autozone? It is just on, not blinking.
    2002 M5 camaro- VTR CAI, custom cat-back exhaust, battery compacitor, pullie, lowering springs, 32mm sway bar, cross-drilled slotted rotars. 1-10\" L7 in cubby.
    nope. get it scanned. there are far too many codes to be guessing.
    1996 Silver camaro Z28. M6,<br />12 bolt, 4.11\'s, posi, Rear cover, Spec stage 2, loudmouth, more <a href=\"http://home.mainstreamtopics.com/?index=3&module=1\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=1</a> &lt;Mods, Pics & more <a href=\"http://home.mainstreamtopics.com/?index=3&module=2\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=2</a> &lt;Fbody Tech Articals
      Good times, i will go to autozone, cause like you all said i guese that the scan is free right?
        yes, it's free. just make sure that you either have them print the codes or write them down for you. AS SOON as they are done scanning and they go into thier "you need to buy X X and X X X to fix X X and X code"... RUN.
          so true....so true. just run! its free and saves time. dont waist a second guessing. thats what its there for ;)
          2000 3.8 A4 Pewter Camaro
            Yeah well it went away, right after i posted this, and hasn't come back all day. So i think i am good.
              it's still going to be in history. get it scaned and be done with it.
                So you are saying that it is going to keep going off? Will the scanner pick it up if the light isn't on at that time.
                  The code was propably written to the history. Unless the fault is not present for a certain amount of key cycles it will remain there. The scanner will read any history code even if the light is not on at the time
