Ok i did the modification to disable my AHLs as shown below in the link, and all is good, the lights stay off, except...one time today, my lights, including dash lights flickered on and off...Can someone explain this?
Which mod did you do? There are a couple different methods to disable your AHLs. I am guessing though that you removed the light sensor and replaced it with a wire. It says in the directions to heat shrink or tape it to avoid a short. If this wire is does short to ground, it can mess with your lights.
