Z28 gauge cluster ? - FirebirdV6.com/CamaroV6.com Message Board
Z28 gauge cluster ?
  • Z28 gauge cluster ?
    Is it the consensus that you have to use the same year gauge from a z or ss to upgrade my 120mph one? Or can I use one from a 01 SS in my 00?
    Thanks,
    Shane
    00 Pewter Y87 Camaro-SS Hood/Chrome rims, Black Halos, Clear corners, Pacesetters, V8 K&N FIPK, 3\" B&B TriFlow, HPP3, MSD Coils, Taylor wires, Transgo stage II, Edge 3000 Stall, 180* thermo, SLP Bowtie Grill<br /><a href=\"http://www.cardomain.com/memberpage/468763/1/\" target=\"_blank\">Carro</a>
    all i did was install an aftermarket 155mph face and plug in the "yellow box" recalibrator from blackrobotics.com [img]smile.gif[/img]
      HMMMMMM? So you installed a whiteface overlay for a Z28 over your V6 gauge cluster and bought a yellow box to fix the speedo?
      Nothing else is off? Nothing else needs to be changed and all works well?
      Shane
        I installed a 93-97 Formula/TA cluster in my 96 V6 bird. No problems.
        Have no idea what year car it actually came out of.
        96 Teal Firebird<br />Colchester, Essex, UK<br /><a href=\"http://www.centrestage.free-online.co.uk\" target=\"_blank\">www.centrestage.free-online.co.uk</a>
          Shane
          The oil pressure gauge wouldn't read correctly if you put the entire V8 overlay on there, but if you wanted to spend the extra cash it might be possible to use a V8 speedo overlay and a V6 overlay for everything else. That's my plan...
          2000 3.8L Firebird, Silver Metallic<br /><br />\"Yes, London. You know, fish, chips, cup o\' tea, bad food, worse weather, Mary f***in\' Poppins, London!!\"
            I think I might just have them made at blackcatcustom.com the way I want it.
            Thanks
            Shane
            • Andy H
              Transmission removal help!!
              by Andy H
            • 2.8 Bird
              Abs inop
              by 2.8 Bird
            • fishin
              by fishin
