fuel injectors - FirebirdV6.com/CamaroV6.com Message Board
fuel injectors
  • fuel injectors
    ok, i need approx 26lb fuel injectors. i can get some 36lb injectors real cheap tho, so i'm wondering if i can lean out the 36lb to the rate of 26lb with an maft? is the maft capable of that??
    --matt
    from what I understand, no.
    I heard it messes up your PCM too when you get all new (aftermarket) injectors
    Soon to be Mommy!<br />2005 Honda Pilot EX-L
      NO NO NO... dont do that...your injectors are supposed to run between 75 and 80% you will need about 250 hp before running 26lb injectors on a v6 [img]graemlins/omg.gif[/img]
        <blockquote>quote:</font><hr>Originally posted by faddis:
        NO NO NO... dont do that...your injectors are supposed to run between 75 and 80% you will need about 250 hp before running 26lb injectors on a v6 [img]graemlins/omg.gif[/img] <hr></blockquote>
        yep.
        --matt
