Dyno Numbers - FirebirdV6.com/CamaroV6.com Message Board
Dyno Numbers
  • Dyno Numbers
    i went to the dyno on saturday and my 96 m5 3.8 only put out 167/109 hp/tq i thought that the torque was kinda low. now i already did the search and figured out how i need to hook it up next time but does the ingition thing really screw up the torque reading that bad i was expecting a lot higher on that side of things.
    1996 Metalic Bule Camaro: no cat BORLA muffler 245-50-16 falken 502\'s descreened MAF 1pc driveshaft<br /><br /><br />soon to come: fixing that dagum Quarter Panel that i jacked up.<br /><br /><a href=\"http://www.geocities.com/heartland_heat_v6\" target=\"_blank\">Heartland Heat V6</a> &lt;----CO-FOUNDER<br /><br /><a href=\"http://www.dahleinsurance.com\" target=\"_blank\">NEED INSURANCE?</a>
    you have a lot more then 109 TQ. it's a false reading...
    1996 Silver camaro Z28. M6,<br />12 bolt, 4.11\'s, posi, Rear cover, Spec stage 2, loudmouth, more <a href=\"http://home.mainstreamtopics.com/?index=3&module=1\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=1</a> &lt;Mods, Pics & more <a href=\"http://home.mainstreamtopics.com/?index=3&module=2\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=2</a> &lt;Fbody Tech Articals
      109 is really low. I think my Saturn has more torque than that.
      New Toy Red 94 Formula LT1
      RT: .0006 60': 1.894 1/8 mile: 8.351 @ 84.89 1/4 mile: 12.974 @ 107.81
      crashed Red 96 Camaro 3.8l: 14.91 @ 92.38
      The ex wife's Black 98 Firebird 3.8l: 15.23 @ 88.12
        ok i was thinking that i just needed reassurance cause i was loosing faith in my six shooter.
          It could have been operator error.
            entirely possible bet i was like the 11th car that day and every one else before and after me got accurate readings.
              its a new setup jake, i wouldn't trust it :\
              maybe next time we have a dyno day, they might have more accurate runs going
              2000 3.8 A4 Pewter Camaro
                actually they have been using the system down in tecumseh and they just moved it up here a guy with his vette got the same results both places it was just hooked up wrong the our ignition.
                  If it was a dynojet, and they went WOT on your dyno pull, it is correct!
                  Dynojets, although they don't get good readings at idle without changing the settings, do get perfect eradings at WOT, by hooking up the machine like you would on any other car. trust me on this one, I ran a Dynojet for over a year at my last job, and only did F-bodies and Vettes 98% of the time.
                  Did your HP and TQ curves cross at 5250 rpm??
                    no they crossed at 9*** somthing it was hooked up wrong they even admitted it i just have to go back next weekend the rpms were wayyyyyyy off
                      Ahh! Well, tell them no need to change the settings in their PC from how they'd dyno an LS1 or Stang (just hook the same old lead to any plug wire, and then ground the other on the strut mount). Also, don't worry about the screen when it shows your RPM's jumping everywhere at idle. When you go WOT, it'll all be right as rain, I promise!
                        tecumseh? that's the name of my tiny-*** town!!
                        sorry, i got excited. not often to find a town with the same name as mine.
                        1996 Pontiac <a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">Firebird</a> <br />Black, 3.8L A4
                          When I've dynoed I needed all the shops to hook up 2 seperate wrires to the spark plug wire to get an accurate tach reading.
                          109 tq is not normal for your 3.8
                            OK got the dyno problem fixed dyno'd 168/ 233
                            that was a lot better.
                              233 is SUPER high for TQ.
