I have a 99 3.8L auto and am experiencing a little problem. I'm throwing a code for cylinder 5 misfire even after checking coil pack and replacing the plug. The weird thing is that it only misfires in 3rd gear (maybe 2nd I'm not sure) when the RPM's get 4500-5500 and speed tops off about 65/70. The car stops revving any higher and won't shift into a higher gear until you let off and accelerate slowly. If you hold the stuck gear to its max for like 2 seconds, it sounds like a golfball in the engine or like the fan or flywheel is hitting something (maybe knock retard) and then SES blinks Cyl. 5 misfire...I dunno if it might be a tranny problem too or if the not shifting and misfire are related. Anyone have similar issues or any suggestions. It would be much appreciated...I'm not into paying a couple hundred at the shop if I don't have to.
When my tank is empty I'm gonna try some 89 or 91 octane to see if it really is knocking (I always run 87). I need to get this figured out before I use the bottle for the first time. P.S. my car has 63000 miles.
