When i start my car its as if the car accelarates and goes to about 1200-1300 rpm and then quickly drops back to 1000rpm or so (normal idle) and also when im drving and i accelerate and then let go, its as if the car stuters a little bit then slows down, anyone have a clue?
Problem when starting car and...
1995 Firebird (3.4) <br />Eagle 18\" 077<br />Flowmaster 80 (2.75\") series exhaust<br />2.5\" Car Sound Cat<br />K&N Cold Air Intake <br />Alpine 12\" Type E Sub<br />Bazooka EL 1500 Amp<br />Pinoeer deh4400 and Aftermarket Speakers<br /> <a href=\"http://www.sounddomain.com/id/fbird\" target=\"_blank\">http://www.sounddomain.com/id/fbird</a>Tags: None
ANYONE1995 Firebird (3.4) <br />Eagle 18\" 077<br />Flowmaster 80 (2.75\") series exhaust<br />2.5\" Car Sound Cat<br />K&N Cold Air Intake <br />Alpine 12\" Type E Sub<br />Bazooka EL 1500 Amp<br />Pinoeer deh4400 and Aftermarket Speakers<br /> <a href=\"http://www.sounddomain.com/id/fbird\" target=\"_blank\">http://www.sounddomain.com/id/fbird</a>
Well. As for the start up, I really wouldn't worry about that.
The part with the RPM's staying up for a bit after letting off the gas. I belive thats a problem caused my the IAT sensor. My car now and then will stay reved up for a bit when I put the clutch in. I'm going to replace the sensor next spring if it keeps doing it.1997 Cayenne Red Metallic Camaro<br />3.8 V6 M5<br />SLP Cold Air Intake<br />Ceramic Coated Pacesetter Headers <br />Flowmaster American Thunder Catback<br />Full 3.42 & Disc Break Rear End Swap
I had a similar problem, I am not that good with mechanics but lemme explain what i did to stop it. It was a cacuum hose that was loose. It was the little plug type thing that is in front of the manifold. It has a plug with 2 hoses going out. It kept popping up, making my car rev high. Try pushing it down, also make sure it isnt torn (mine was) if it is, go to a GM store and order the part.. i think it was about $12 or so. Good Luck!
--Fierdon1995 3.4L A4 Firebird White w/T-Tops *SOLD*<br />**NEW CAR**<br />2004 White Cavalier Coupe<br />2.2l ECOtec 5 speed
It could be your fuel regulator.99 camaro... WingsWest body kit, Billet grill, EBC Green Stuff break pads, tint\'s all the way around, magnaflow exhaust, ram air, Rebuilt trans, 3300 stall, and RS 3 alarm. FFF kit! <a href=\"http://www.cardomain.com/memberpage/452573\" target=\"_blank\">http://www.cardomain.com/memberpage/452573</a>
