Ok, Ive got a rattling thats progressively worsening. Its somewhere up front and sounds worse when I turn on the A/C. From what I understand its probably the heat shield comming loose. Only thing is I have NO idea where it is AND what to tighten and look for *doh*. So let a brotha know. Grats.
heat shield??s
I have the same thing you are describing and it is the shield around the cat. (Large bulbus thing about mid line in your exhaust) I have not messed with mine as of yet but as far as I know the only way to fix it is to removeit or take it to a shop and have it rewelded. Hope that this helps.Remember that sometimes, silence is the best answer.<br />Warren White<br />1996 PoloGreen Coup <a href=\"http://vampyr.settanni.net/\" target=\"_blank\">http://vampyr.settanni.net/</a> <br />\"Jealousy\"<br /> CTFBA member of the month Sept 03
Simply look under your car and follow from the y-pipe all the way back to the muffler looking for a small aluminum sheet (heat shield) touching your exhaust components...or near your exhasut components. At that point, when you find it, take a pair of pliers and bend the part touching out of the way.- Josh<br />If you have any questions or need installation pics/help, e-mail me: Viper98885@aol.com<br /><a href=\"http://Camaroz28.cardomain.com/id/viper98885\" target=\"_blank\">\'93 Camaro Hardtop</a><br /><a href=\"http://Camaroz28.cardomain.com/id/01lincolnls8\" target=\"_blank\">\'01 Lincoln LS8 Sport</a><br />\'00 Yamaha YZF-R6<br /><a href=\"http://www.ftpp.net\" target=\"_blank\">Full Throttle Performance</a>
if that doesnt work..take it off..i did, nothing bad happens...not worth bringing it to a shop to get fixed...just cut the bands and it will fall off! hope this helps94 3.4L A4 white t-tops<br />moroso cai<br />3\"hi-flow pacestter exhaust<br />b&m shift kit<br />catco cat<br />01 T/A rear w/ 3.73\'s and posi<br />1 pc aluminum ds<br />blacked out signals
Might be the perforated shield on the CAT too. That will also come off with a little work. I had this same problem on my '88 and '98.
Just don't park over anything that may catch on fire after you remove it.--Traded In--<br />1998 Navy Blue Metallic Camaro (RS)<br />3.8L V6 w/4L60E Auto<br />Sport Appearance Package<br />T-Tops - Loaded<br />_ _ _ _ __________________ _ _ _ _ <br /><br />--New--<br />2003 Victory Red S10 Xtreme w/Silver Stripes<br />2.2 L4 w/MW2 5 Speed Manual<br />LS Package
by DongrossmdI’m new. I actually don’t own a Camaro or firebird. I do have a 2000 Camaro 3.8 fly by throttle and 4l60e. This is installed in a 1980 Triumph TR7...5 days ago
