Lights pop up but no light. - FirebirdV6.com/CamaroV6.com Message Board
  • Lights pop up but no light.
    If I run a hot wire straight to the brown wire of the head lights. They will pop up and light up normal.
    Lights have 3 wires black [ground]
    green [brights]
    brown [reg lights n motors pop up]
    I checked all the fuses. Can't find a problem anywhere. Since when I hot wire the lights. They light up and the motors work.
    Why don't they light , like normal when the motor pop up with the switch???
    Seams funny that they are obviously on the same circuit.
    But power from the switch in the dash only makes the motor pop em up. But hot wired to the brown wire on the head lights. Will make both the lights lite up and they pop up normal???????
    BuickThunder.com<br />\"Think out side the bowtie\"
    What I don't get is why the lights pop up but wont light with the stock switch.
    If the motors get power, so should the lights.
    As if I hot wire the brown wire, they pop up and light.
    It makes no sense. If the motors pop up, they should also light.
    They both obviously are wired on the same circuit.
