ok, i used to be able to spin the tires from a dead stop just slamming the gas, i cant do that any more... (i know part of my problem is my sub box)... but i was able to do it a little with that in... what im wondering is where the EGR sensor hooks up to the headers.. i have a leak (does anyone know what i can do about that) and do you think that could be a reason for losing some power?
Question about lost power
Green 97 Camaro RS 30th Ann.<br />3800 II<p><b>MODS</b><br />BORLA rear exhaust section, RKSport Headers, Hi-Flow Catylitic Converter, SLP CAI, Sylvania Silver Star Headlights, Eibach Pro Springs, Bilstein Shocks/Struts, 1LE Front/Rear 32/21mm Sway Bars w/Poly Bushings and Poly endlinks<p>And a bad @SS MTX SystemTags: None
Welcome to the hot summer, where tires grip and engines lose power running 220F.2002 5-spd NBM Camaro
Details: www.1lev6.com
yeah i know what u mean, im in North dakota, heats not too much of a problem... im mostly wondering what i can do about my leaky egr, i know that it leaks where the hose connects to the header.... ive tried tightening with no luckGreen 97 Camaro RS 30th Ann.<br />3800 II<p><b>MODS</b><br />BORLA rear exhaust section, RKSport Headers, Hi-Flow Catylitic Converter, SLP CAI, Sylvania Silver Star Headlights, Eibach Pro Springs, Bilstein Shocks/Struts, 1LE Front/Rear 32/21mm Sway Bars w/Poly Bushings and Poly endlinks<p>And a bad @SS MTX System
you will lose power down low with that leak but might actually be a little faster at highway speeds. I dunno if a little leak in the EGR would make as big a diff. as the heat and humidity, even in ND.7\"TV, DVD player, WW ground effects<br />2800 stall, aluminum DS, NX wet kit<br />15.39 (G-tech) stock w/3.42 LSD
is there anyway to seal that place better so it doesnt leak, its annoying makes a gay noiseGreen 97 Camaro RS 30th Ann.<br />3800 II<p><b>MODS</b><br />BORLA rear exhaust section, RKSport Headers, Hi-Flow Catylitic Converter, SLP CAI, Sylvania Silver Star Headlights, Eibach Pro Springs, Bilstein Shocks/Struts, 1LE Front/Rear 32/21mm Sway Bars w/Poly Bushings and Poly endlinks<p>And a bad @SS MTX System
hey man, i know how you feel, i have the same problem w/ my pacesetter headers. i think im about to jb weld my tube to the headers, ill let you know how that works. you can also buy a small block off plate ($5) online. and just pull the EGR tube and let it hang loose, your engine will run quite a bit cooler, but you will lose about a mile of gas per gallon, and you car wont pass an emissions test._davjos81- 02 v6<br /><a href=\"http://www.cardomain.com/id/davjos81\" target=\"_blank\">www.cardomain.com/id/davjos81 </a><br /><a href=\"http://community.webshots.com/user/davjos81\" target=\"_blank\"> <a href=\"http://community.webshots.com/user/davjos81\" target=\"_blank\">http://community.webshots.com/user/davjos81</a> </a> <br /><br />-over $8,000 invested! Too many mods to list, just check out my site!!
