help, when i turn right there is a squeek the faster i go the louder it is. it sounds like keys scrapping or a chain dragging on the highway. power steering pump??????? please help. (diff. problem) when i stop there is this loud horrible ruhhhhhhhhhhhhhhhhhh as i stop could it be cause it has been pooring rain the past day??
when i turn right there is a squeekkkkk
sounds like your brakes with the ruhhhhh. i also think you squeek is the same as mine but i dont know what would cause it other than somethins with the brake/steering setup. but it doesnt sound like a pump problem
im not really sure. its definatly common though cause mine does it along with alot of other f-bodies i have seen around town
mine did the aqueaking when I turned when my pads got low and the little squealer doo hicky was hitting the rotors. It got progressively worse until it did it all the time, not just when I turned
by ssms5411So my truck is finally getting some work done, after 17 years, Oil pressure sensor went out and it’s located under the lower intake manifold. Have to...3 weeks ago
