SES Code 5th Cylinder Misfire - FirebirdV6.com/CamaroV6.com Message Board
  • SES Code 5th Cylinder Misfire
    so, service engine light came on today, being a little scared I went to autozone and they checked it out. The code on the little machine he had said P305, and it said "5th cylinder misfire".
    I don't know how to approach this?
    I have a friend who has a later model grand am gt, and his said a "4th cylinder misfire" so he replaced the 4th cylinder plug, wires and coils. And I guess I'm scared about what to do. Also, when the car starts, it seems to have a high sparky noise, i dunno if that means anything, maybe it's a knocking noise, i do not know. :( please hellllllp!
    ~The Guru\'s Guru~<br />1999 Camaro,K&N,!MAF<br />!airsilencer,3.08s,<br />NGK-TR6\'s,Taylor Blue 8mm wires,FRAM,A4,Catco Cat, Magnaflow 3 inch catback,transgo shift kit<br />Waiting: RK sport headers, custom y pipe electric cutout<br /><a href=\"http://www.cardomain.com/id/divinejc\" target=\"_blank\">www.cardomain.com/id/divinejc</a>
    also, I still have my powertrain coverage.. will that be covered under this?
      If its still under warrenty go to the dealership! They will take care of it.
        that's part of the powertrain right?
            moving to general.
            Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
              once again our fearless leader has helped another one :rolleyes:
              yeah, you shouldn't have a problem with warranty work.
              2011 Camaro LS 6M, in black.
                yeah but I guess my warranty is really stingy, like they might not cover diagnostics and such. Plus they are being a ***** cuz I bought my car at a ford dealership, and they're tell me to go to a chevy dealer to use my warranty!
                Man, what a waste of money
                  Go to a Chevy dealership for the warrenty. It dosent matter where you bought the car, the warrenty is with GM. GM pays the dealership for the work on warrenty.
                  Factory:Camaro 5 speed, Color Pewter, w/ t-tops and Y87 package. <br />Engine: K&N filter w/ Whisper Lid, FRA, Borla adjustable cat-back exhaust. Hurst w/ Short Stick<br />Interior:Oil temp. and Air/Fuel ratio gauges, System.<br />Exterior: Black outs front and back, 18 in. Lenso rims w/ Kumho Supra 275/35ZR18 tires, also limo tint on sides and back.<br />173.2rwhp-----200.5tq
                    i had a similar problem...my spark plug wire was grounding itself on the exhaust manifold. you may just need to put new wires in. every person i know personally who drives a v6 camaro have had this problem with the stock wires. mine read misfire too...and it was covered by carmax warranty.
                    [ July 23, 2003: Message edited by: mrbako ]</p>
                    1998 Chevrolet Camaro L36 M5<br />1982 Toyota Celica Supra 7MGTE project car - FOR SALE<br /><br />\"I find the most sensual part of the woman is the boobies.\" - Zap Brannigan
                      Most likely it's the wire and possibly the plug. If it was a coil it would be missfiring on 2 cylinders. Not just one.
                        Read the warranty again, & go to dealership where bought for more explanation. I bought my 99GP from a chrysler place & got an extended warranty. What happens is that I let the Moopar peeps know something is up, they log it & say ok, we'll tow it (if need be) to Poncho dealership for warranty work. when it's done, I pay my deductable & Mopar picks up the balance. I went through this w/the starter on the GP, & was glad I had the waranty [img]smile.gif[/img]
                        2013 Ram 1500 Big Horn
                        94 comero 3.4
                          i asked and they said it wasn't covered by the warranty because the problem relates to the ignition system, not the powertrain :( . Here's what happened, a friend of mine has the little device that plugs under the dash, and he got the code. Well, he erased the code and it hasn't come back!! It's been about 100 miles and it's gone. What does this mean?
                          Also it seems as if the car smells a little hotter. I don't know if it comes from that, or the fact that I have a pinion seal leak that I need to get fixed but I'm too lazy!
                              It sounds like the problem is fixed.
