Your codes are probably caused from your missfire on cylinder #6, i'd start there first. All you really need to replace is the plug and wire. But most people like to change out all the plugs and all the wires to give it a good balance.
Have had missfire codes on 2 seperate occasions...once on #4 and once on #6. Turned out to be bad plug wires. There's a TSB out for 98s concerning bad wires that leads to missfires. Both times the dealer fixed the problem for free under the TSB.
