Calibrating a 150 mph gague cluster? - FirebirdV6.com/CamaroV6.com Message Board
  • Calibrating a 150 mph gague cluster?
    If anyone swaped their 120 mph gague cluster on their 96, A4, 3.8L for a 150 mph gague cluster, were you successful in calibrating it properly?
    We're planning on swapping mine for a silver face gague cluster, and if we're going to do that, I was thinking we might as well go to a 150 mph.
    Of course if it isn't going to work properly, and there is nothing we can do about it right now, I don't think we want to bother going to the 150 mph.
    Any suggestions?
    P.S. I did a search on the topic, on this board, and came up with nothing.
    Jana<br />-Black,1996 3800 V6 Camaro with T-tops, Powerdyne 6 psi. SC, intercooled, front mounted ATI air to air two core intercooler, K&N Air Filter, Suncoast Ram Air Hood, Z-Style, with Air Box, Four wheel disk brakes conversion, with LS1 front brake conversion, 3.42 Gears, Cross drilled directional Rotors, BMR Strut Tower Brace, Flowmaster 80 Series muffler with 2.5\" inlet, and 3\" outlet, dual, chrome exhaust tips (soon to be full Flowmaster Thunder Series Catback with Pacesetter Headers), Stock LT1 Formula sway bars (soon to be 1LE\'s all around), 17 x 9 ZR1/SS chrome rims, with Firestone Firehawk 275/40/17 tires, Bilstein SLP valved shocks, Eibach springs, SLP Subframe connectors, BMR adjustable Torque Arm, 1LE Aluminum driveshaft, Taillight cover black-outs, Turn signal black-outs, Custom 3800 V6 decal, Off-road pipe, 160 Thermostat, SLP Fan Control Switch, B&M Transmision pan, B&M Shift Plus, Herb Adams solid adjustable PHR, etc.<br />-Soon to be added, headers, lightweight k-member.<br />-All thanks to my wonderful, supportive boyfriend, Rob, with the red hot 94 Firehawk Formula at: <a href=\"http://www.robshawk.com\" target=\"_blank\">Rob\'s Hawk</a><br /><a href=\"http://www.robshawk.com/Jana/Camaro/\" target=\"_blank\">Jana\'s Camaro</a>
    your speedo will reed no differnetly than it does now...
    yoru tach however will be different... you can get adapter from dakota digital..
    also, this is not advanced so I'm moving it to general.
    Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
      n00b's! ;)
      Thanks Magnus.
      ________________
      Rob
      1994 Firehawk#319
      11.83@120.61
      Slightly Modified
      1996 Blown V6
      2002 Trailblazer
      San Diego F-Bodies
      "What do you mean, "I hurt your feelings"? I didn't know you had any feelings."
      Rob<br /><a href=\"http://www.robshawk.com\" target=\"_blank\">1994 Firehawk#319</a><br />11.83@120.61<br /><a href=\"http://www.RobsHawk.com/MODLIST.txt\" target=\"_blank\">Slightly Modified</a><br /><a href=\"http://www.RobsHawk.com/Jana/Camaro/\" target=\"_blank\">1996 Blown V6</a><br /><a href=\"http://www.RobsHawk.com/NewTruck/images/100_0011.jpg\" target=\"_blank\">2004 Silverado</a><br /><a href=\"http://www.RobsHawk.com/Trailblazer/TrailblazerSm1.jpg\" target=\"_blank\">2002 Trailblazer</a><br /><a href=\"http://www.SDFB.org\" target=\"_blank\">San Diego F-Bodies</a>
        what is the website for dakota digital?
        Longtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,
          <blockquote>quote:</font><hr>Originally posted by SLOWBRAEATER:
          what is the website for dakota digital?<hr></blockquote>
          :rolleyes: http://www.dakotadigital.com
          ~Derrick <a href=\"http://www.appstate.edu/~do54457/\" target=\"_blank\"><i>My Webpage</i></a><br /><b>\'96 3.8L V6 M5 Firebird Y87</b> | <b>162.8 RWHP</b> / <b>196.7 RWTQ</b> <br /><b>•</b> SLP CAI <b>•</b> <a href=\"http://tech.firebirdv6.com/y87.html\" target=\"_blank\"><b>Y87</b> Package</a> - 3.23s <b>•</b> 180º thermo w/ fan switch <b>•</b> TB spacer from DEE<br />1991 Jeep Cherokee Laredo 4x4
