Ignition Coilpacks - FirebirdV6.com/CamaroV6.com Message Board
Ignition Coilpacks
  • Ignition Coilpacks
    What sized socket does it take to remove these darned things on my 97 3.8?
    When I did mine I found out the easiest way to do it is to take out the plate that the coil packs sit on. That way you can just swap them out and put the plate back in. When I put my MSD coils in, I also took a black permanent marker and wrote the numbers on the top like you see on the stockers.
    But to answer your question, I think it's somewhere around a 6 or 6.5mm. It's been over a year since I did it.
    2000 3.8L Firebird, Silver Metallic<br /><br />\"Yes, London. You know, fish, chips, cup o\' tea, bad food, worse weather, Mary f***in\' Poppins, London!!\"
      Just did it, 5.5mm
      94 Firebird 3.4 - RIP<br />97 Firebird 3.8 - In the works
        7/32 works also
          ^^yup...i did it by just removing the plate too
            Like FunkZ said,
            if you're careful, you can use a standard, non-metric socket and get it. If you're not careful, you could round off the bolt head, but in my experience it isn't usually installed really tight.
            \'00 f-bird 3.8 M5 coupe, pewter metallic<br />Torsen LSD, Pro 5.0 shifter, Spec stage 1 clutch, Y87 muffler, aftermarket stereo<br />-more fun than the Oldsmobile it replaced...
              Originally posted by tWiStEdBird:
              Just did it, 5.5mm
              Tried that, along with 6mm, 6.5mm, 7mm, 8mm, 9mm, 10mm, 11 / 12mm too!! No go!... It just won't lock on and feels too loose...
              How do you take off the entire module? I don't even see how it bolts on.
                use a 5.5MM, make sure that it says 5.5. the heads might be striped.
                  If the heads are stripped, how can I get it out?
                    if you can remove the whole braket to where you can actualy bring the coil packs to you and use vise grips to remove the bolts you can then replace the bolts once they are out.
