What sized socket does it take to remove these darned things on my 97 3.8?
Ignition Coilpacks
When I did mine I found out the easiest way to do it is to take out the plate that the coil packs sit on. That way you can just swap them out and put the plate back in. When I put my MSD coils in, I also took a black permanent marker and wrote the numbers on the top like you see on the stockers.
But to answer your question, I think it's somewhere around a 6 or 6.5mm. It's been over a year since I did it.2000 3.8L Firebird, Silver Metallic<br /><br />\"Yes, London. You know, fish, chips, cup o\' tea, bad food, worse weather, Mary f***in\' Poppins, London!!\"
7/32 works also1994 Firebird 3.4<br />15.65 @ 86.8<br /><a href=\"http://www.funkz.net/firebird.htm\" target=\"_blank\">funkz.net/firebird</a><br /><a href=\"http://mywebpages.comcast.net/funkz/timeslips.htm\" target=\"_blank\">Timeslips</a>
^^yup...i did it by just removing the plate too<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
Like FunkZ said,
if you're careful, you can use a standard, non-metric socket and get it. If you're not careful, you could round off the bolt head, but in my experience it isn't usually installed really tight.\'00 f-bird 3.8 M5 coupe, pewter metallic<br />Torsen LSD, Pro 5.0 shifter, Spec stage 1 clutch, Y87 muffler, aftermarket stereo<br />-more fun than the Oldsmobile it replaced...
Originally posted by tWiStEdBird:
Just did it, 5.5mm
How do you take off the entire module? I don't even see how it bolts on.1997 Camaro RS W/T-Tops<br />All Stock / 200 HP
use a 5.5MM, make sure that it says 5.5. the heads might be striped.1996 Silver camaro Z28. M6,<br />12 bolt, 4.11\'s, posi, Rear cover, Spec stage 2, loudmouth, more <a href=\"http://home.mainstreamtopics.com/?index=3&module=1\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=1</a> <Mods, Pics & more <a href=\"http://home.mainstreamtopics.com/?index=3&module=2\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=2</a> <Fbody Tech Articals
if you can remove the whole braket to where you can actualy bring the coil packs to you and use vise grips to remove the bolts you can then replace the bolts once they are out.1996 Silver camaro Z28. M6,<br />12 bolt, 4.11\'s, posi, Rear cover, Spec stage 2, loudmouth, more <a href=\"http://home.mainstreamtopics.com/?index=3&module=1\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=1</a> <Mods, Pics & more <a href=\"http://home.mainstreamtopics.com/?index=3&module=2\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=2</a> <Fbody Tech Articals
