Misfire?????? - FirebirdV6.com/CamaroV6.com Message Board
Misfire??????
  • Misfire??????
    alright guys....
    i know its been discussed before and i searched but my problems a little different.
    everytime im going up hills in a higher gear normally around 1500-2000 rpm i get alot of hesitation and also accelerating in a high gear.
    i changed my plugs and wires not too long ago so could it still be them??
    i was planning on changing my coilpacks but really i dont want to unless it's absolutely necessary
    thanks
    1994 white Firebird M5<br />Flowmasters, CAI, 3.73s, LSD, coated pacesetters, eibach pro-kit, bilsteins, hurst shifter, JVC stereo, 18\" C5 vette wheels, Kuhmo Ecsta ASX rubber<br /><br /> <a href=\"http://www.cardomain.com/memberpage/744299\" target=\"_blank\">http://www.cardomain.com/memberpage/744299</a> <br /><br />Coming Soon: Turbo!
    If you are going up a hill you want to increase your rpm's....downshift...1500-2000 rpms is too low for going up hills. It might be ok for a Z28...but not a V6. Do you have an SES coming on? If you don't then it might be just a case of bogging the engine down.
      maybe a vacuum leak
      2000 3.8 A4 Pewter Camaro
        sounds like a fuel restiction, contaminated MAF or a wire..
        1996 Silver camaro Z28. M6,<br />12 bolt, 4.11\'s, posi, Rear cover, Spec stage 2, loudmouth, more <a href=\"http://home.mainstreamtopics.com/?index=3&module=1\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=1</a> &lt;Mods, Pics & more <a href=\"http://home.mainstreamtopics.com/?index=3&module=2\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=2</a> &lt;Fbody Tech Articals
          ^^thats what i was thinking...check your pump/filter [img]smile.gif[/img]
            i havent changed my fuel filter in a long time i was thinking maybe that
            i dont mean a steep hill like a slight incline
            SES does come on sometimes just when i let off the gas and coast
            what could that be?
            thanks for all the help so far guys
            also bout how much does a fuel filter cost?
              cheap. like less than 10 bucks and 10-15 before for a good brand
                ses coming on with decel is generaly an EGR fault... a scan would help
                  i thought they have to use that key thing on my car....
                  OBDI
                    you need a shop with an OBDI scanner..
                    • 187shark
                      by 187shark
