SES woes...WTF? - FirebirdV6.com/CamaroV6.com Message Board
SES woes...WTF?
  • #16
    Well, after consulting chilton, I think I'll wait for just a little while to fix this (unless I can avoid removing the entire EGR assembly).
    If it won't affect my gas mileage real bad, I'll just let it be until my rebuild (scheduled for soon).
    2005 Ford Focus ZX3 SE D20 M5 - Modified ;) <a href=\"http://www.knightenmotorsports.com\" target=\"_blank\">http://www.knightenmotorsports.com</a> <br />[ U R L = h t t p : / / w w w . g e o c i t i e s . c o m / h e a r t l a n d _ h e a t _ v 6 ] Heartland Heat V6 [ / U R L ]
    • #17
      EGR is tested on accel and decel, thats why you get the code then.. A scan will be the only way to attack the problem tho. That will give you the best coruse of action to take. It could also be something else. But if the EGR is stucking open then it will make the car run bad, run rich and can burn up the cat..
      1996 Silver camaro Z28. M6,<br />12 bolt, 4.11\'s, posi, Rear cover, Spec stage 2, loudmouth, more <a href=\"http://home.mainstreamtopics.com/?index=3&module=1\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=1</a> &lt;Mods, Pics & more <a href=\"http://home.mainstreamtopics.com/?index=3&module=2\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=2</a> &lt;Fbody Tech Articals
      • #18
        The cat...yeah... :D
        but is does run a little rich. I'll prolly wait a little and just rebuild it in a month or two.
        • 187shark
          by 187shark
