Should I go from 5W-30 to 10W-30 oil? - FirebirdV6.com/CamaroV6.com Message Board
  • Should I go from 5W-30 to 10W-30 oil?
    Just like the topic says...
    I am changing my oil this weekend, and I was thinking about doing this. I have 104K on my 3.4...I want the better protection of a thicker oil, but I do live in CT. I don't think it'll get cold enough for dry starting in the winter...what do you guys think?
    Thanks in advance [img]smile.gif[/img]
    --<b>David</b>--<br /><a href=\"http://bryant2.bryant.edu/~dsantore/index.htm\" target=\"_blank\">The <b>NEW</b> V6Bird Website!</a> <br /><a href=\"http://members.cardomain.com/thev6bird\" target=\"_blank\">Cardomain site</a><br />ΔX
    no.
    2011 Camaro LS 6M, in black.
      your choice
        Why go and change oils when 530 works just fine? I have 102K and my oil pressure stays at 39 stopped in drive and 65 @ idle.
        1993 Pontiac Firebird 3.4L V6 A4<br />F41 RPO suspension option<br />119K miles<br />Fastchip<br />K&N \"Filtercharged\"<br />Airbox cuttout CAI<br />ASP underdrive pulleys<br />Pacesetter Headers<br />Flowmaster 80 Series 2.75 cat-back<br />MangaFlow Hi-Flow Cat<br />Corvette Servo<br />16.4 @ 81 MPH
          I just changed....I'm staying with 5W-30 [img]smile.gif[/img]
            I've always ran 20W-50 in my Mustang and I ran it in my Camaro a few times. I feel safe with a thicker oil in Florida. But I think my Camaro is good with 10W-30. I've never used 5W-30.
            My Car: 1994 Camaro 3.4 V6 5-Speed<p><a href=\"http://www.cardomain.com/id/speedyman_2\" target=\"_blank\">My Car</a>
              10w30 is not thicker than 5w30 when hot.
              2002 5-spd NBM Camaro
              Details: www.1lev6.com
                Re: Should I go from 5W-30 to 10W-30 oil?
                hes right. But 5w40 is!
                  Refresher time:
                  Multi-grade motor oil
                  The temperature range the oil is exposed to in most vehicles can be wide, ranging from cold ambient temperatures in the winter before the vehicle is started up to hot operating temperatures when the vehicle is fully warmed up in hot summer weather. A specific oil will have high viscosity when cold and a low viscosity at the engines operating temperature. The difference in viscosities for any single-grade oil is too large between the extremes of temperature. To bring the difference in viscosities closer together, special polymer additives called viscosity index improvers are added to the oil. These additives make the oil a multi-grade motor oil. The idea is to cause the multi-grade oil to have the viscosity of the base number when cold and the viscosity of second number when hot. The viscosity of a multi-grade oil still varies logarithmically with temperature, but the slope representing the change is lessened. This slope representing the change with temperature depends on the nature and amount of the additives to the base oil.
                  The API/SAE designation for multi-grade oils includes two grade numbers; for example, 10W-30 designates a common multi-grade oil. The first number associated with the W (again 'W' is for Winter, not Weight) is not rated at any single temperature. The "10W" means that this oil can be pumped by your engine as well as a single-grade SAE 10 oil can be pumped. "5W" can be pumped at a lower temperature than "10W". "0W" can be pumped at a lower temperature than "5W", and thins less at temperatures above 99°C (210°F). The second number, 30, means that the viscosity of this multi-grade oil at 100°C (212°F) operating temperature corresponds to the viscosity of a single-grade 30 oil at same temperature. The governing SAE standard is called SAE J300. The motor oil grade and viscosity to be used in a given vehicle is specified by the manufacturer of the vehicle.
                  Many new vehicles are marked to use 5W-20 oil (Honda, Ford and more recently Toyota). Some ultra fuel efficient and hybrid vehicles are marked to use 0W-20 oil.
                  Source: The always dependent and reliable Wikipedia...
                  • Andy H
                    Transmission removal help!!
                    by Andy H
                  • 2.8 Bird
                    Abs inop
                    by 2.8 Bird
                  • fishin
                    by fishin
