Ok here it is, when i first take off froma lights or a dead stop my car will hesitate,shake, sounds like it is misfiring,but when i get it up to speedlike around 60 and cruise it is ok, last time i took it in tocevy they said it was a loose plug wire, it was fine fora while but now it is doing it again? any ideas?
Spark plug wires
The idle isn't smooth. It doesn't rev smoothly through the RPM range, & often times you will get a flashing SES light that hints there's trouble somewhere in the ignition. You can also place your hand in the exhaust flow, & smell raw fuel on your hands as a result of the loss of total combustion caused by the problem.2001 Onyx Black Camaro M5-Totalled<br />2005 Ford F150 XLT 5.4L<br /><br />\"To make peace, prepare for war.\"
