Not the usual grinding gear problem. This was something different that I spent money to fix that I didn't need to. A while ago my pop up headlights didn't go up on the first flick of the switch, I had to turn them on, then off, then on again very quickly. Mechanic said it was probably the switch so I replaced the 100 switch. Still didn't work. So I just said f it. A couple weeks ago my abs and ebrake lights kept comming on, and I was told here to check my battery connections. That solved both problems at once. The connections were corroded and dirty causing the headlight and abs/ebrake light problems. Both fixed for free. So really this is just an fyi post so no one else spends 100 bucks on a headlight switch. [img]graemlins/thumbsup.gif[/img]
Pop up headlighs not working
<a href=\"http://www.cardomain.com/id/briansr\" target=\"_blank\">97 White Pontiac Firebird 3.8 A4</a><br />Mods- 2.75\" exhaust, Dynomax muffler, magnaflow cat, SLP CAI, Hypertech 160* thermo, Fan switch<br />Suspension-Kumho Ecsta 712\'s, 32mm/19mm sway bars<br /><br />Our Lady of Blessed Acceleration, don\'t fail us now. <br />-Elwood BluesTags: None
thanks! mine has been doing that for a long time. i'll have to check my connections. maybe this is my problem with my alternator, too...\'96 <b>Quasar Blue</b> Firebird A4<br /><a href=\"http://jamiethekiller@comcast.net\" target=\"_blank\"><i>jamiethekiller@comcast.net</i></a><br /><a href=\"http://www.woodlandrock.com\" target=\"_blank\">my band: woodland</a>
