do i just unbolt the bad one.. remove it, and just replace it? no wireing involved? or would i have to take the whole plate off, and do it from there?
[ July 28, 2003: Message edited by: Tyler ]</p>
96 Camaro M5. Dark metallic gree (?dont know the offical color name)<br />Home made Intake :: Headers, 3inch headers back to Flowmaster muffler :: spec stage 3 clutch Now installed, waiting for 3.42\'s and LSD next month<br /><a href=\"http://photobucket.com/albums/y192/RiceEatingCamaro/?action=view¤t=newcar.jpg\" target=\"_blank\">My Car</a> <br /><br />Totalled Car.<br /><a href=\"http://bellsouthpwp.net/s/k/sk8er305/\" target=\"_blank\">96 CamaroRS</a>
ok... what tool should i use to get to these tiny bolts?? i dont have much room to work with since its the coil in the back (1 and 4)
is it possible to remove the wire plug from the harness? i cant seem to get it off
I NEED HELP!! im limited on tools since my dad is at work.
what size tool do i need to get the damn wireing harness off???
ok.. i installed the coilpacks.. (all 3, thanks to magnus) and i still get the misfire..
could it be the plate that the coil packs sit on? so far i've replaced : spark plugs, wires, and coil packs.
now i guess all i got left to replace is the damn plate that they sit on.
anyone got any part numbers? or ideas?
thanks
so whould autozone check my ICM for free? it would involve work to get to the ICM...........
Check you plug wires also, you may have a bad wire, or one that's not completely on the plug. With the headers, make sure you didn't burn through the insulation on a wire. They're coated, so they're not supposed to get as hot, but they doesn't mean they won't.
[ July 30, 2003: Message edited by: Guardsman ]</p>
