v6 to v8/ls1 swap - FirebirdV6.com/CamaroV6.com Message Board
v6 to v8/ls1 swap
  • v6 to v8/ls1 swap
    Im looking to swap a ls1 into my 2000 firebird could this be done for 5kish? including labor? How much am I looking at?
    maybe. ls1s are still pretty pricey. are you doing it yourself or having it done at a shop?
    Follow me!
    Or this
      nevermind i just saw the labor part. theres alot of work that has to be done to get everything right so im gonna say more like 6kish. due to suspension, rear end and alot of other stuff.
      Follow me!
      Or this
        I'm not exactly sure if the rearend has to be swapped because I believe it's the same thats on a Z28 besides the gears... but I could definately be wrong...
        ...Here's what you're looking at...
        Engine / K-Member, Harness
        Transmission / Tourque Conver or Clutch
        Suspension
        Computer
        Fuel Tank/Fuel Lines/Fuel Pump
        Gauges (if you want accurate readings)
        Exhaust
        It's probably going to run you closer to 7K minimum unless you come across some HELLA deals... The best and easiest way to do it is buy a LS1 Salvage car...
        Also I highly reccomend before dropping that engine in that you do heads, cam, maybe even a stroker to the LS1 just to make the swap worth it otherwise you'd be WAAAAAAY better off just buying a Z28 or T/A...
        In otherwords, unless you're willing to invest atleast an additional 5K in mods to the LS1 for about 400 - 500 HP... The swap SERIOUSLY isn't worth the time and money...
        [ May 28, 2005, 10:32 AM: Message edited by: Need4Camaro ]
        1997 Camaro RS W/T-Tops<br />All Stock / 200 HP
          yeah i was talking more about the gears and lsd for the rear.
          Follow me!
          Or this
          • 187shark
            by 187shark
