Hi guys, I did a search for this question and didn't come up with anything. I'm aware that when you upgrade to a high output alternator (I'm going to a 180amp) you need to upgrade your re-charge wire to 4 gauge. I was just wondering if it's a difficult procedure to do, taking out the old wire and hooking the 4 gauge one in in its place? I'm planning on installing the new alternator and wire in the upcoming week so I was just wondering if I should expect much trouble...
That would work but that's way to expensive. All you need is a few feet of 4-awg wire (5-feet should be plenty....better to have some extra to play with than be too short), 2 4-awg ring terminals and some split loom tubing. Check out Partsexpress.com for everything you need:
i was one of the first people to get their HO alt from them, so i was the guinnie pig [img]smile.gif[/img] But no complaints here 2 years later and its running strong.
You can go to auto zone and they have 4 gauge wires with the proper ends already crimped on. They go for like $5.00
Ok awesome. Here's the other thing I meant to ask...how did you guys go about running it? Is there a way to run it directly to the battery like the current one does? I could probably hook it up to the power block but wouldn't that ruin the purpose of getting a 4 gauge wire...the wire going from the block to the battery is back down to 8 or 10 gauge it looks like. Did you guys open up the battery terminal and put the new wire or what? Just wondering what works the best.
Don't use that "power block." Go directly to the battery itself. They make an adaptor bolt which allows you to use the factory terminal at the battery but it also allows you to add on additional wiring. Just simply remove the 8mm bolt holding the terminal on to the battery and use the adaptor bolt. Adaptor picture
As far as routing the wire, just follow the path of the factory wire that goes to the alternator. Just keep it away from the exhaust or belts/pulleys. Use Zip ties to secure the wire as you run it.
Here ya go. [img]smile.gif[/img] Should sell those locally too. DO NOT connect to the + block! And follow the wire path that is there already. You're nukin it man. Couldn't get much easier. [img]smile.gif[/img]
Originally posted by 96firebird311: Here ya go. [img]smile.gif[/img] Should sell those locally too. DO NOT connect to the + block! And follow the wire path that is there already. You're nukin it man. Couldn't get much easier. [img]smile.gif[/img]
Damn you nda! Beat me to the punch! :D
Lol thanks for the advice, I know I'm asking stupid questions here...but after all I'm still a teenager, so it's allowed! I just wanted to doublecheck things so I don't end up screwing something up...thanks again for the help you guys.
I've just got the side posts and then a power wire that leads off into a seperate power block the the left of the battery right behind the headlight. The other thing I was thinking the other day is all my stereo equipment is wired to that block as opposed to the battery. There's a smaller lead going from that block to the battery so in a way thats kinda holding back the power my system gets isnt it? Am i better off just upgrading that wire to 4 gauge as well and just making a whole new terminal out of it with that wire and the new alternator recharge wire to plug into the battery?
Had to be evacuated Monday again after a fire was going on the hill behind us. Only 3-4 hours, they did a good job getting it under control. Especially...
