idk y but for some reason whenever i tryu and throw it in reveerse its like the gears r still spinning ya kno and it clicks as it goes in and grinds..and its only in reverse when it does this..wut could be the problem here
clutch grinds in reverse
try going into 5th before you put it in reverse. i think i read somewhere that theres no soliniod ( spelling ) in reverse. i had to replace my clutch master cylinder too. my clutch was stuck to the floor.1998 bright red camaro ,M5 ,Y87 ,stock<br /><br />Originally posted by Rune:<br />If it smells like a turd and looks like a turd, chances are its probably not a candy bar.
Totally normal. There's no synchro on reverse gear (or a different type according to others...beats me) so it'll do that. Just put it in fifth then into reverse. Nothing to worry about.Matt
1998 Mystic Teal Camaro M5
synchro...yeah, thats the word. i was close. i knew what it was i just couldnt think of the word.i thought i was right [img]redface.gif[/img] :( thanks 98camaro3.8 i think you helped me figure out what was wrong with my clutch too right? changing that master cylinder was a PITA and took forever. thanks alot.
edit: sorry for the confusion, im learning1998 bright red camaro ,M5 ,Y87 ,stock<br /><br />Originally posted by Rune:<br />If it smells like a turd and looks like a turd, chances are its probably not a candy bar.
by Andy HHey everyone! I've been trying to remove my transmission for two days now! I need to replace the clutch. Only thing I've got left holding the transmission...4 weeks ago
