i went to get it inspected today and it failed they said that the exhaust was so free flowing that the computer didnt even pick up any numbers has this ever happened to anybody else and the exhaust is only 2.5 :mad:
WTF my car failed inspection
you still use that inspection stuff wehre they put the rod in the exhaust?
PA uses OBDII scanners. they just hook the car up to a scanner and it reads teh o2's.
my car passed, it took like 5 seconds for them to do it.
take it to a different center. there is no WAY you will fail, you dont have any major mods.
maybe hes just a mustang owner whos scared of your car. [img]graemlins/rofl.gif[/img] [img]graemlins/rofl.gif[/img] [img]graemlins/rofl.gif[/img]help me build the ultimate sleeper soon ill have a lot more mods than i can list and watch out for the spikes. 02 firebird
its not clear what they meant by "computer didnt pick up any numbers". did they mean that the computer didnt see anything on its sensor or that it rejected the readings due to too much dilution? if you have an exhaust leak its possible that you are not getting enough exhaust gases to the tailpipe. either its leaking before it reaches the tailpipes or air is mixing with the exhaust gases (dilution). if you have a dual exhaust one side might test 'better' than the other (with the borla and a closed plate, checking the passenger tail pipe will yield zero emissions).
or his equipment could be broken.
