locked my only pair of keys in the car - FirebirdV6.com/CamaroV6.com Message Board
  • locked my only pair of keys in the car
    '94 Camaro
    how can i get in it (aside from breaking the window)?
    do you have t tops? get a coat hanger and unlatch the t top, then pull it out and get in through the roof
    Mystic Teal Metallic
    ET:15.1 NA 14.3@96 MPH 75 Dry Shot
      no t-top.
        lock smith
          straiten out a coat hanger, slid it through the window, and hit the unlock button assuming you have power windows.
          95 Firebird<br /> <a href=\"http://www.cardomain.com/memberpage/673250\" target=\"_blank\">http://www.cardomain.com/memberpage/673250</a> <br /> <a href=\"http://photobucket.com/albums/y217/andrewbrandon19/\" target=\"_blank\">http://photobucket.com/albums/y217/andrewbrandon19/</a> <br /><br />me on a good day------&gt; <a href=\"http://communicatio.webblogg.se/images/wet_cat_113159625.jpg\" target=\"_blank\">linky</a>
            yes, you need something wedge like to pry open the window a little without damaging the molding. Then get a coathanger in there and pull the lock switch back.
            2002 Pewter V6 Camaro M5 <br /><br />Quickest stock-motor N/A V6 4th Gen F-body.<br />2nd Quickest N/A V6 4th Gen F-body overall.<br />mods: Gear, weight reduction, tuning <br /><br />Fear the Gear. 13.585 @ 100.05 1.827 60\'<br /><br /><br /><a href=\"http://www.NJFBOA.org\" target=\"_blank\">www.NJFBOA.org</a>
              materials needed
              -1 flathead screwdriver
              -one whatever screwdriver
              -straight sitck(thinner then screwdriver handle. yard stick?)
              -screw
              Put screw in end of stick at a right angle
              Then use one flathead, to pry the window away fromthe roof, then stick the other screwdriver handle in between the roof and the window to hold itopen, then put the flathead handle in there too and slide it to the side to make a decent sized ga p along the top.
              use the stick with a screw on the end to go in the window, then use the screw to hit the slide on the lock and slide it over.
              then take the screwdrivers out and open the door.
                i dont think you can unlock from the inside of a locked car.. you need to pull the switch back. How about trying to pop the trunk button.. if you have crank windows just push it down a little. if its easier use a coat hanger or something like it to unroll the window... or if the keys are in the ignition, try turning the key forward, then pressing the window roll down button if its power windows
                  Huh?
                  Are you saying if you lock the car when you're inside it, you can't unlock it?
                  Matt
                  1998 Mystic Teal Camaro M5
                    I think he is talking autolocks...
                    I know the rear hatch disables after the car being off for awhile.
                    Just do what I said works quickly and easily. I did the "crank a window down thing" before but that was because I only had a metal pole at the time.
                      Originally posted by 98Camaro3.8:
                      </font><blockquote>quote:</font><hr />Originally posted by teal99camaro:
                      Huh?
                      </font>[/QUOTE]thats only true if you use the remote lock on your key ring
                        Listen, this is what i would try to do... using a coat hanger, go in from the back of the window. Slide your fingers in between the back of the window and the weather stripping and gently pull out a little bit, just enough to give yourself some room to work one end(bent to form a closed hook) of the coat hanger to push the unlock button of the power lock switch on the door.
                        I locked my keys in the 'Maro last summer and this was how i got into my car to retrieve my keys! I tried going in from the top but i was afraid of screwing up the weather stripping. So, try going in from the back with a coat hanger(i think i had to use two in order to reach).
                        You will find this technique makes it kind of easy to break into a Camaro. Yeah, it scares me too... but i guess that is why the alarm is there. Hopefully, whatever the criminal is trying to get at takes them longer than the 5 seconds(or whatever it is) until the alarm goes off.
                        Hey, good luck!
                        2000 Monterey Maroon Chevrolet Camaro<br />3.8L V-6/4spd Auto
                          I can say my method works, done it twice on my 94, 1-2 times on my 3rd gen and easily 6-7 times at this guys 3rd gen at my work. [img]smile.gif[/img]
                          I have seen people at the track pry the window so far back they reached and got the lock with there hand
                            close, camaroKrazed...
                            my keys were in ignition, just before start
                            I don't have power locks, but i have power windows (the motors need to be cleaned), and someone helped me push the passenger side window button down with an antenna, from the driver side, and i got in from the passenger's side.
                              sweet!
                              I used a slim jim on mine (never used it before) took me 5 minutes tops
                              push it in and hook something in the door and pull up
                              done
                              course now my lock makes a funny noise :(
                              millionformarriage.org
                              Why stop people from getting married?
