What plugs with a Maft + - FirebirdV6.com/CamaroV6.com Message Board
  • What plugs with a Maft +
    i was thinking of hooking up my maft + i was wondering what plugs i should use with it. i was thinking NGK TR6's. right now i have bosch plus 4's in it.
    thanks mike
    Silver 2000 Firebird A4<br />3.8 A4<br />14.746 @91.98 Feb /03/02<p>1990 Mitsu GSX 5Spd I just got it.<p>Otis for President 04 !!!!!!
    I think you can use any plugs with the maft+. The only thing you have to use ngk tr6 with is nitrous.
    Longtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,
      TR55's NA
      TR6's N20
      Also, I'm moving this to general tech.
        Those tr55 are ngk correct? Man i dont know about the tr6 im sure they are great for nitrous but every ngk plug i used for n/a didnt last very long and fouled out i then changed to the way to expensive bosch +4 and didnt foul any more plugs.... go figure
