High Beam/ Fog Light - FirebirdV6.com/CamaroV6.com Message Board
  • High Beam/ Fog Light
    Anyone know how to make your fog lights stay on when you turn your high beams on? Im asking this for a 99 Firebird
    If anyone knows how pics would be a great help too.'
    thanks
    Mike<br /><a href=\"http://www.my99firebird.gq.nu\" target=\"_blank\">www.my99firebird.gq.nu</a>
    Yes, basically you ground a green wire [img]smile.gif[/img] Very simple.
    The hard part (10minutes if youre slow) is getting the fuse box out of the fuse holder and clipping the wire - attaching a wire to it - and grounding the sucker.
    Instructions can be found here:
    http://www.xious.com/camaro/install-foglamps98%2B.html
    2002 5-spd NBM Camaro
    Details: www.1lev6.com
      cool thanks dom
        1. Open the hood
        2. Disconnect the negative (-) battery cable.
        3. Open the black box that contains fuses and relays on the driver's side.
        4. Twist off the plastic screw and take the cover off.
        5. Find the fog-light relay, labeled in block H. There is a list of labels for the
        wires inside the box cover.
        6. The Black box is held down by 6 plastic retainers connected to the frame,
        push them in with a flathead screw driver and pop off the bottom piece.
        7. Look at the bottom where the wires go into the box, and locate where the
        fog light relay is. You should see the following wires:
        orange - yellow - purple - light green
        8. Cut the light green wire. Then get some extra wire (e.g. speaker wire) and attach
        it to the end of the wire coming out of the relay box. This gives you enough length to
        ground it. Use one of the hex-head screws holding the left fender piece as the ground.
        Even though the fender is fiberglass the screw still touches the frame. Unscrew it a little
        bit and wrap the wire around and retighten the screw.
        9. Put electrical tape around the end of the (dead end) light green wire coming out of the
        harness.
        10. Put the Box back on its mounting, it should snap into place.
        11. Put the cover back on.
        12. Reattach the negative battery cable.
        13. Check the fog lights, low beam, hi-beam, and then fog+hi beam.
        *** Notice: The amber light on the fog light switch which lights up when they
        are on, WILL still go out when HI-BEAM is activated. Its no big deal.
        The circuitry inside the light selection switch still turns it off.
        94 Quasar Blue Z28<br /><a href=\"http://www.9t4z28.com\" target=\"_blank\">http://www.9t4z28.com</a><br /><a href=\"http://www.9t4z28.com/Dyno1.htm\" target=\"_blank\">http://www.9t4z28.com/Dyno1.htm</a>
