brakes are sensitive, low trac, clicking noise. - FirebirdV6.com/CamaroV6.com Message Board
  • brakes are sensitive, low trac, clicking noise.
    Everynow in then i tap the brakes and the car will throw you forward the low trac comes on and the car starts clicking. Im assuming its the abs. It happens more often in the rain when the brakes are cold. I will be going 5 mph tap the brakes the car throws you forward and start clicking like crazy. When the brakes are warmed up it stop. Any ideas of what this could be?
    1995 3.4L M5 Camaro<br />Bullet Performance Exhaust, K&N FIPK, Stage 1 clutch, Short shifter, Hotchkis STB, Taylor Ignition wires, NGK spark plugs
    a crappy abs sensor. could be ur tire pressure too high too.
      All the tires have been checked and are at 35 psi. Where can I get new sensors and how much do they usuall cost. Can I install them myself?
