Would a bad EGR valve cause a inconsistant idle and also cause a chugging while cruising? Just trying out every possibility to fix my problem.
Also, can I just try cleaning it instead of replacing it because it is not a cheap part.
Thanks in advance for the info.
Modifications:<br />headers, throtle bod spacer, flowmaster, high flow magnaflow carsound cat, powerdyne sc with 2.9\" pulley and by-pass valve, walboro 255 fuel pump, spec stage 2 clutch, and HP Tuners
yes it will cause those problems, you can try cleaning it with carb cleaner and as long as the valve inside isn't just worn out it will fix the problem
96 Firebird, Ram Air Hood and Airbox, Magnaflow Catback & hi-flow cat, Dynomax Bullet muffler
3 days ago
