How to dismantle pop up headlights? - FirebirdV6.com/CamaroV6.com Message Board
  • How to dismantle pop up headlights?
    On my 99 bird, my headlights pop up automatically when i gets dark out, i want to stop this from doing this and be able to turn my fog lights on with out having the dam headlights on. How do i do this?
    99 Firebird Vert, Pewter Metalic<br />Fast Toys Ram Air<br />Jet Stage 2 Chip<br />17x8 Mille Miglia Emotion II Plus\'<br />wrapped in 245/35/17 Yokohama A520<br />Rhino Perf. Exhaust<br />K&N air filter<br />check pics at:<br /><a href=\"http://www.fastrides.com/members/v6birdy/\" target=\"_blank\">http://www.fastrides.com/members/v6birdy/</a>
    on my car at least, theres four settings for the headlights, off, parking lights, on, and brights. The parking lights one just turns teh fogs on for me, it doesnt open the headlights, I know this doesnt help but I figured id post it neway.
    1998 Firebird 3.8, A4<br />Mods: Alum Ds, Yank TC 2800 stall, Rksport lid, FTRA, SLP air temp sensor, K&N, Flowmaster catback 2.5\" w/cutout, 3:42 gears w/LSD<br />Best E/T: 15.6 @ 86 mph (w/o gears / lsd or verter)<br />Best 60: 2.234<br /><a href=\"http://www.teamfoxfire.iwarp.com\" target=\"_blank\">www.teamfoxfire.iwarp.com</a> -- club site<p>To come?: l67 piston package hardened, turbo? spray? low 12\'s? well see
      ok..to disable your automatic headlights...
      http://nikon.250free.com/headlight.gif
      try and follow this diagram and read on to try and follow me....goto radioshack get a dual throw switch...3 leads off of it....+ , ground , and the second +....if you remove the center thing around your radio and removing your radio helps too...you will be able to lift your dash up slightly...just enough to get to the vents on your dash..y'know where the led for the alarm is...following me so far?...ok right next to the led you will see a sensor (little black thing) with two wires coming out of it...the way this works is when 2.37volts(I believe, did it a while ago)is sent through to your the blue wire the car thinks its nighttime....when no voltage is sent through its daytime...now you can tottaly disable your auto headlights by removing this sensor...you'll then have to use the switch everytime....or if you make the somewhat complicated switch you can choose.... ;) ...hope this helps
      [ October 26, 2002: Message edited by: nikon ]</p>
      05' CTS-V
      00' Camaro - SOLD :(
        This is all you have to do. You don't even have to use a resistor. You can just use a jumper wire. (I used a resistor just in case)
        http://eyeoutthere.tripod.com/lights.htm
        <b>LS1 RX7! </b> &#0124;&#0124; <a href=\"http://www.no-bling.com/image_galleries/index.php?action=viewgallery&gallery=galleries/eyeoutthere_LS1_FC\" target=\"_blank\">Full Gallery</a> <br /><br />LT1 Header Informtion/survey
          that tottaly disables auto though....with my thing you can have normal auto...or have it off like yours ;)
          05' CTS-V
