Bad coil pack? - FirebirdV6.com/CamaroV6.com Message Board
Bad coil pack?
  • Bad coil pack?
    At lunch today I was looking around the engine bay and noticed a couple cracks on top of the coil pack for cylinders 3 and 6. The crack is about 1/2 an inch long and there is another 1/4 of an inch crack perpendicular to that one. They both have what looks like to be brown corosion around the cracks. Is that just a cover on top of the coil packs and is it nothing to worry about or am I getting moisture in there and that is what is causing the rough idle and chugging at cruising speeds.
    Sorry if this is a stupid question but I am not to familiar with coil packs.
    Also, how do you gett them off and is it a complicated job?
    Modifications:<br />headers, throtle bod spacer, flowmaster, high flow magnaflow carsound cat, powerdyne sc with 2.9\" pulley and by-pass valve, walboro 255 fuel pump, spec stage 2 clutch, and HP Tuners
    hmm.. sounds like you need a new coil pack. if you have a misfire in wet weather, its prolly cause of that. in any case, a cracked coil pack, or ignition module wont help performance any. id recommend replacing it as soon as yuo get the chanc. you'll need a 5.5mm socket to get the bolts off that hold teh coil pack in place. besides that, its an easy fix. good luck
    phill
      Thanks, I replaced it last night and started the car and it ran worse than it did before, the car was rocking back and forth when I first started it and when I tried to drive it around the parking lot it wouldn't idle down all the way. So, I unplugged the battery to clear the PCM and let it sit overnight. This morning it started
      normally, still running rough at idle but it seemed to have a little better acceleration and did not miss as much at cruising speeds.
      I still have one original coil pack left I might try changing that one and see what happens.
        I know you might have done this already but you might want to check the wires are tight and in the right plugs (#1 going to cylinder 1, #2 to 2 and so on) and then check the connections at the plugs completely disconnect and then reconnect the wire to the plug. with the headers I'm sure that's a pretty simple job unlike those of us who have to crawl under the car to get to 4 of the 6 plugs.
        -Brad
        2000 V-Star Custom 1100
        :rock:
